Identifying an 11.50 rear axle?
Front Driveshaft, need special T-40 Tool
What size or part number for track bar bolt?
How do I know if I have an 11. 50 rear axle? I ordered a Hellwig swaybar, #7651 and it doesn't fit, though that's the part number for an '06 2500, UNLESS you have the 11. 50 axle. So, besides the swaybar not fitting, how do I check my axle size? I looked on the driver's door post. There are two stickers, both give me details on weights and tires/rim sizes, but nothing about the axle. Any other suggestions?
In the glove box is a sticker that tells you what the truck was built with, or your local dealer can tell you based on the V. I. N.
I can tell you for sure that the '06 has a 11. 5" axle. All trucks with the Cummins motor built after Jan. 1 2004 have the 11. 5" axle as well as the 50 state legal H. O. motor.
Ditto...
The 06' 2500 with Hemi would have the 10. 5".
