Isn't that what I said?
I wasn't challenging what you said - just commenting on it. Sorry if it offended you. Have a nice day.
Rusty
I'll add a little more to this statement, if the engine isn't set up correctly for extended idle time, (not high idle) it will run a lot cooler and amplifies the condition Sag2 mentions. An engine that runs at lower than designed temperature, can cause early wear, not just the valves, but premature cylinder and bearing wear as well. High idle with EB on should be OK, but the early 6.7's turbo soot issues were blamed on long idle times. I know when my 6.7 was on the dealer computer, the tech would always comment on the idle times. I know it wasn't sitting and idling for long periods, so I ignored the comments, but they do look for it.Idling for long periods of time, especially in very cold conditions leaves too much unburned fuel and leaves deposits on the valve guides that can stick the exhaust valves. The fastest warm up is to drive the truck after letting oil pressure come up. Next best is plug it in and have winter front. If you do choose to idle it the best way is fast idle with exhaust brake on to add load to the engine.
I checked last night. My truck is just under 20K miles, 49 hours idle and 445 driving hours. No way in HEdoublehockey sticks that I have 49 hours of idling time.
Not changing a thing. Not complainimg. Just showing that the idle hours can be counting wrong.
I know mine is counting wrong ,I have 61hrs idle time, no way in hell, in 33 months ,and 25K. I idle for a few minutes only when letting the turbo cool down
If you hit 25-30stop lights per month and also cool.down your turbo a couple of times a week and get stuck in bumper to bumper traffic a couple of times per year, you can easily average 2 hours of idle time per month.
Cummins2014[2492975 said:If that is the case do they look at idle time as something negative or is it relative to actual run hours .
in cummins commercial engines the throttle position sensor is 2 parts ,the tps and an idle validation switch which is simply an on-off switch tells the ecm when the pedal is in the idle position,so anytime your foot comes off the accelerator the ecm sees the idle signal,records time as idle time,and that adds up over time.not sure if dodge uses the same type throttle position sensor,but I bet they do.
Good question. I was told 10-20% Idle time is normal. But I don’t know if that is compared to total hours or drive hours. I think it is compared to total hours.
I was a bit taken back by the following post
But I'm pretty sure the ECM communicates with the BCM to get speed governor info (reducing fueling to prevent you from going an unsafe speed) and it also gets Torque Management calcs from vehicle speed in the manual transmission trucks. For example, Torque management in the G56 transmission trucks is most noticeable below 40 mph.
What we need to find out is :
What things are used in idle time calcs?
I thought it was RPM & speed =0. But it might instead use Throttle position? Or maybe it uses all three?
I think the ratio (idle/total)is of some importance. But also total hours is of most importance to someone gauging the life of the engine... along with maintenance records. I have only been putting date and mileage on my maintenance records. I did once though take a picture of my engine hours screen . But from now on I will be including idle/drive hours on my maintenance records .
Well I am pretty much spot on if its 10-20% . Just went out to check it again, and I was actually 66 idle, and 619 run hours just over 10%.
Yep. Those numbers are good. Interesting that people who ran the legendary 1997-1998 5.9 12 valves never worried about idle time. That was before EGR & DPF
