I'm Piersified and lovin it
HX35 auto vs manual?
DTT TC help from anyone
If any of you guys are sitting on the fence, so to speak, regarding Piers Govenor Spring Kit... Don't be! Even with the problems I've had, I'm as happy as the proverbial fly on poo-poos. :D :rolleyes: :D
Like racingfanscjww, I was always looking for a way of getting over the grade at higher speed then 54 mph. That's where my truck would top out pulling the trailer in third with the 4:10 rears and an auto transmission. If I shifted to overdrive on a grade at 54 from third, I'd be on the back side of the torque curve and I couldn't accelerate. :( I was stuck going against the govenor in third at 54mph. NOT ANY MORE! :D ! :D Now, I can power up to about 65 and then shift to overdrive. Powersmokes move over, the mighty Piersified Cummins is is going to make you eat dust and cough smoke. :cool:
I swear that GSK and the readjusted lever make the truck perform better then I dreamed. I think the lever was always partially stuck under the plate :( and underfueling. The truck just woke up and now, with the GSK, it pulls HARD right to about 3450 RPM. I can light the tires at will now ,couldn't do that before, and the truck quite litterally jumps up and roars to life. :eek: More smoke and EGTs too but if I slide the plate back to help EGTs and slide the AFC housing back a bit to help with low end fueling and adjust the star wheel, she will be purrr-fect.
Sorry Bill, I guess I'm not looking so longingly at that Cranberry colored F*rd anymore. I was eyeballing it pretty closly at Tulare when Bill said ,"It's for sale" especially when my truck was DOA.
Piers and Blair saved my rear at Tulare too, because of a lost woodruff key in the shut off lever and the truck never turning off at 2 in the morning. That's yet another story.
So, get on that phone and call Piers at 1-604-853-9396 and order yours today so you too can "be all you want to be"! :D
-Paul R. Haller-
ya but i got the ever elusive pdr hitch cover
he he he
paul does that trailer pull well at 120mph... ... ... ... ... ???? he he he
Hitch cover?? Dang missed out on that one.
If anyone willing to drive to the Houston area that needs help with there 12 Valve I am here for ya.
Also Piers gives me some good pricing on parts so I might be able to help in that area, just let me know.
-- email address removed --
Michael
Paul,
I was very happy to see your results. :D So much so I ordered my spring kit from Piers yesterday. I hope it has the same effect on my 3500. I'll keep in touch to let you know.
timing degrees btdc?
What is the "Nevada Intake"?
Also, What is the best timing setting for a 96 5 speed, with a # 11 TST cam plate?(best mileage most important, then power).
This is my first time guys, so if I am screwing up, please be nice. :)
Thanks
Tommy
Tommy, welcome aboard. It's always good to see new faces on the site. About your timing question, 15 to 15. 5 degrees seems to be a good place to start. That should equal 5. 9 to 6 mm of lift if you are using delivery valve lift as a measurement. Hope this helps.
Don Quaethem
