@AH64ID the Fleece bypass thermostat is rated at 180* … I surmise it is meant to start opening a little sooner then the OEM 190* in order to promote more even flow from back (hottest) to front (coolest) part of the block.
Personally I wouldn’t want that for towing. Knowing how the fan is programmed I’d want a 210° thermostat in it to ensure proper operation of the fan and OE thermostat when towing.
Not sure what options there are, but I recall it being a SBC thermostat.
Not sure what the problem is … the bypass thermostat starts opening at 180 but the OEM thermostat that it ties into doesn;t open until 190, so as far as I can tell, it just promotes flow through the block until the main thermostat opens at the factory specified temp.
At that point, they are both circulating thorough the radiator as well, which is still cooled/controlled by the ECM/fan.
What am I missing??
The issue is occurs when you end up running cooler than the OEM 190° thermostat would have you running, so the fan won’t cycle like it should while towing unless you’re making a lot of heat.
John, I'm probably just being thick headed and am NOT trying to be contradictory … but since the main thermostat is NOT opening yet (until 190), isnt the rear themostat being open at 180 just promoting a more even heat distribution between the cylinders and NOT cooling down overall temps, even at lower loads ??
But the rear bypass thermostat only connects to a riser ABOVE the OEM thermostat which is remaining closed until 190…doesn't that mean the bypass thermostat is just recirculating coolant in the block until the OEM thermostat actually opens ???
Maybe thats what I am unclear on..the direction of coolant flow.
We both live close to the coast but your oil pan looks much better than mine
Under light loads only the rear thermostat will be open, which means you’ll run cooler and reduce efficiency too.
The 180° thermostat is better for race applications, but for towing you want the main thermostat to be the primary regulator of the engine temp, not the secondary.
