The windshield washer hose came apart at a spliced joint. Unfortunately, I can't find a way to to get to it to repair the splice. The hose runs a circuitous route from the fluid reservoir at the front of engine compartment (driver's side) then over the top edge of the radiator to the passenger's side, then through a space under the air cleaner, above the wheel well, and behind the headlight before continuing on via the cowl to the washer ports. Guess where the break is. Is there an easy and inexpensive way to get to it for repair, or do I need to train a small octopus to do that job for me?
