I replaced my lift pump the other night thinking it was on its way out. After everything was installed and primed liked it should be truck started right up, sat there and idled just fine, and good response all the way to WOT. Problem solved, right, or so I thought.
Haven't driven it in a couple days because I was messing with the TPS among other things. Went out this morning before work and started it up. Fired on the first crank just like usual. Went out 5 minutes later and it had stalled, the same way it did Monday morning when I suspected the lift pump. Hit the key and it just cranked over. Put the pedal on floor, cranked for 30 seconds and it fired but would only stay running at WOT. Repeated and same result. As soon as I back off of the pedal it dies. I know it has fuel in it, the filter is new, the lift pump is new, now I am really suspecting the IP.
Anybody else ever have this kind of problem? Is there something else I should look at or try? If it is the pump, is there a common problem that could cause this?
One last thing. If the old VE is giving up the ghost, should I rebuild or just buy a reman pump?
Help... ... ... .
Help... ... ... .
