I had a VP replaced in October of '03 on a 2000 model year bluebird. The new pump has 22,153 miles and has now begun to exhibit the same symptoms.
I tested the lift pump psi at WOT under load and seems to hold just above 6 psi. 12psi at slow idle.
I will be sending it to the dealership for the recall on the lift pump/injection pump for industrial engines. They said the school may have to buy a injection pump outright as it was replaced once already
The engine derates and cuts out periodically. One of the nozzels stopped squirting fuel so I replaced that and she runs great at a slow idle now. Just not too well under load.
Engine code is not active, so I cannot pull it out of the computer. It's only active when engine is in the derated mode. Wish I had a computer to test this. The engine flash codes just don't get it.
Scott
Scott
