injection pump
KSB stuck
will 1994 f600 with 5.9 fit in my 93
can an older VE injection pump be replaced with a newer P7100 pump for more adjustment settings?
Yes... BUT, it will entail significant expense and work in order to work properly and effectively. Also, some parts will need to be hand fabbed from scratch to make this conversion work. In most cases it's cheaper to find a 2nd Gen engine and drop that in rather than struggle with the labour intesive job of alterations/modifications to accomodate the P-pump.
Antrim93 replied.....
"..... Yeah it can and Its not as bad as some make it out. If you can find a P7100 for a good price,Also injection lines and front cover. If you have any questions P. M. me... . "
Moved here from FAQ Forum. .
pb. .
