Does anyone know if the injector fuel connectors can go bad? If so are there any sound or noises that come from a bad one? I have had a slight tapping noise coming from my truck at light throttle. First I thought is was timing. Then replaced FCA,Cascade valve, replaced CP3, bought F1 40HP injectors, Now that I can tweak the setting on my smarty and stack with quad race pressure only I can really hear when turning up the rail pressure. Timing does not effect it at all. Its something between the CP3 pump and the injectors. Checked the pressure relief valve on the rail. That's not it. It seems to be tied to throttle position and only will make the noise once rail psi is over 13500 psi. Not really tied to RPM. Any thoughts?
