injector pump mechanics
wheels idea?
Tough part to clean
Can anyone recommend a good place to get my pump rebuilt locally (Charlotte, NC)?
Is there any special tools I need to R&R my pump? I'm not a diesel mechanic, but I'm not scared to do it(I do all my race car work). Any tips or things to look out for?
What should it cost for a pump rebuild?
What is spill port timing - how do I check/adjust it?
I've got the big blue manual from Chrysler, but I can't find spill port timing in it.
Hey, sorry for all the questions, but I know you guys have the answers... ... thanks
Whit
Give Rowell's Diesel shop a call, they are located in Indian Trail (just east of Charlotte) 1-800-383-1030 or locally 704-333-5213. I'm sure if they don't do it in house they will know where you can get some help, good luck...
Real BOMBers never get speeding tickets. . just a lot of warnings!
I'M SCARED!
The only reason I didn't reply is that I've had all of my engine work done by Ted Jannetty @ JRE in Connecticut. I realize it's a ways from NC but it's even further from Nashville, Tn. I thought it was worth the drive to have my pump done right and accurately timed (1. 35mm) by JRE (203)753-7223. Just my opinion... ...
TDCanuk! I just read your siganture and it's not true! I was issued a ticket just last night on my way home for 64 MPH in a 50 in the mighty Cummins. He didn't buy the line when I told him, "I'm not in a hurry & beside Diesels are slow!"
Keeno
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a replaced 12cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil, Rhino liner, Fully Chrominated Aluminum Aftermarket Accessory T-handle Shift Knob
Hey KEENO... Good to see you're back. . and postin'.
All the way to Connecticut, too? those folks at JRE DO KNOW JACK about those VE44's.
For you guys and gals looking for an injection shop in your area, and don't have a clue, look in your yellow pages, call and set up a visit. Introduce yourself, check out the facility, can they do the COMPLETE job there? How are their personnel, are they rushed? ask your questions, OBSERVE, LISTEN.
Are they experienced with your engine, pump, and truck? Do they bench set and flow there?
Likely as not they won't rebuild YOUR pump, as they would refit a newly rebuilt one. (saves downtime on your truck)
Ask about their warrantee.
Lastly, do they talk the "turning up" talk? How would they? What is your comfort factor with all of this?
Start calling and visiting, and remember these people are in business, you are the customer seeking the place to do business, the quality shops will stand out by their patience and knowledge.
'98 Cummins 12v, Big Medicine. Got Diesel.
http://www.ecpe.vt.edu/~dfritz/RIDES/frank_s/classic92.htm
Have you tried to contact Power Wagon on this subject?
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft
Try www.boschdiesel.com for a list of factory authorized dealers.
'93 W350 Club Cab, Bright White, 5 sp. , 130K, Factory Options: LE, 4. 10 Limited Slip, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck ball, 10,000 lb receiver, Tekonsha brake controller, POWER WAGON injectors-WAY faster than stock!.
Sorry! That's www.boschservice.com for dealer list.
Too early and no coffee.
Look into UPS-ing it to these guys. www.wentlanddiesel.com
Home of the Power Wagon injectors.
'93 W250, LE, CC, 4x4, 5spd. , Cummins, K&N, 16cm turbo, Power Wagon injectors, Professionaly rebuilt and calibrated pump, straight exhaust, Lund visor w/lights, 5th wheel, Gooseneck, H. D. rear hitch, Aluminum everything. My Rigs
