Engine/Transmission (1994 - 1998) Injector Question
Engine/Transmission (1998.5 - 2002) warranty blues ...
I currently have 215 Bosch injectors in my truck along with a #6 TST plate pushed forward. My timing is set at 18. 5*. My head is O-Ringed and the exhaust ports are ported. I still have the cat, but that will leave soon and be replaced with a 24V resonator. My muffler is gone and on the front end I have an AFE filter assembly. My turbo is still the original WH1. I would like to know what injectors (in progression) will add more power with minimal smoke! I am not a fan of clouds of black smoke and will not tolerate any more than a second or two of smoke before the turbo spools and catches up. My mechanic thinks I should be in the 280-300 H. P. range and I would also like to know what the injector steps will add to my power level. I have a line on a HX35 if I need to step up, I will. This truck is still a daily driver and has to crank and run when I need it! The transmission has been upgraded to take whatever I dish out. Thanks in advance!
Ronco
