1. The manuals that some fellows refer to about injector/valve spring installation-Is this the same Dodge Service Manual Geno's Sells?
2. Does the manual specify valve spring installation?
How to find top dead center of each piston?
3. Where can the valve spring replacement tool be purchased from?
I find the number and tool numbers from Miller Tools for the Injector Puller and Connector tube puller. I am mechanical able just want to have the right manual that tells you what you need to know and also the right tools for the job before beginning. Thanks to all who can answer any of my questions. All local diesel shops I trust with my truck are busy and I am very picky about my truck so I should be able to handle this job with no trouble. Thanks to sag2 for the awesome write up.
