RamBill, You will need at least the 16cm2 housing to get the full benefit from your engine with the PW injectors. The injectors them selves will make a big difference, but you will want more air via the quicker spool of the 16cm2 housing or even the 12cm2 with a modified down pipe. Low resriction air filter. Also lose the muffler for straight pipe or low restriction muff. As Al states your truck came stock with 18cm2 housing. IF you plan on getting real radical with the fuel in the future you might want to hang on to the 18cm2 for more flow and less EGTs. That would be the last resort for final performance tuning! Read: Fully BOMBED!
You have gauges right?
Owner: Stabco Repower. '89, CC, SB, 5sp, 3. 54, 16cm2 housing, maxed fuel, KN, Banks exh w/muffler, Horton fan clutch, Autometer liquid filled gauges, Factory tach option, 100% Dyna-Mat, Borgeson steering shaft, Firestone air bags, Chrysler V-twin air comp, 2. 5" lift, Rancho Shocks, Alcoa LTS wheels, BFG 255/85/R16 MTs (33. 3")
