Engine/Transmission (1994 - 1998) Inline pump p/n help.. PLEASE
Engine/Transmission (1998.5 - 2002) Check Engine light...
Engine/Transmission (1994 - 1998) Loud Clicking While Braking
Anybody know anything about a 130 hp calibration on the 6BT with inline pump? Or what pump this number is?
3929404
Thanks,
Brayden
Is it possible to change barrells and plungers in all the inline pumps? I'm thinking about buying this one and changing it...
That is a Cummins or other mfg. number, not the Bosch number. The Bosch # is on the side under the place where our linkage "tripod" is bolted.
If the pump has the usual two studs holdig down each barrel, you can probably change them to the ones found in Dodges--if you don't already have a barrel with the same PN. However, the camshaft may be different and may even have a different firing order.
The pump isn't worth much if it is such a low hp unit--may have very few parts that interchange with stuff used in Dodge applications.
Brayden,
The pump on eBay is not (IMO) a P7100. Looks a bit like a Bosch A pump but I'm not sure. The bid price is already more then it's worth for me. HTH's, Larry
Thanks Roger,
I've got a slightly used pump that I'm going to run, but didn't know if this brand new one would be good for 400 hp or so after a "tune up". .
Thanks again,
Brayden
