I have one on order from Turbo Re-Source now, hope to have it in a few days! After a brief discussion with Tom, I opted for his "Stage 2" modified HE351CW since I have the BBI Stage 1 injectors. Tom's specs for this turbo are:
67x76mm Turbine wheel, 60x86x90mm billet compressor wheel. Tom estimated it should flow 10% over stock, 64lbs/min and 928CFM. So, I am hoping this turbo along with a SteedSpeed 3rd gen exh. manifold will get my EGT's in check when towing in higher elevations. No sense bolting on a better turbo with a choked up stock manifold, right??
In case my signature line does not show up, it's an 05, 48RE, 3:73's, 4wd, BBI Stage 1, headstuds, Pacbrake PRXB direct mount, Smarty S-06 with UDC Coffman Tuning (thanks John!) GDP2 kit, 285/75R17 Nitto Terra Grappler G2's
The tunes are great!! your tow tune is a big improvement over the box tunes when I got the trailer behind me!! and has yielded decent MPG when I am not on it. Once I start moving a little more air with this modified HE351, I feel I will be right where I want to be. Once I get the new turbo and exhaust manifold in and down the road, I will post some results for everyone to see.*
I just found out the hard way with allot of white smoke that my turbo is shot. I am running a Smarty Jr on setting 1, truck is bone stock except a cold air intake with a big silicone hose from the airbox and a FASS lift pump and a 48RE from ATS. I called Turbo re-source and they recommended not just the 6.7 mod but also an aluminum wheel similar to the wicked wheel but not as extreme. Is this what you guys had installed? Also when you port matched the PDI exhaust manifold did you do that work or send it to Turbo re-source? If you did do the port matching, what was the procedure? Thanks
I kept the stock compressor wheel and the 6.7 turbine wheel with the turbine housing modified by Turbo Resource to fit the 6.7 turbine wheel.
