no articat you are right, no need to go that way, one pump is more than sufficient to supply fuel to the VP44.
i was under the impression that both pumps need to be connected will be running on demand the one near the tank to feed the stock and i think that ECM does recieve signals from the stock pump as to if it is drawing any current and if that is the case then it could give error codes, if you know that it does not then i stand corrected, in that case the electrical hook up as you mentioned would work fine.
bob
bob
