Well 65k miles, hauling the slide in or the horse trailer or both has finally done in the leafs and overloads. I am starting to sag in the back end, that is the truck is sagging. I seem to be on the overloads all the time now empty. So, I bought the air bags over the weekend and was wondering a couple of things on the install.
First, I have to drill 8 holes. Since I have a Short Bed I drilled some 1/2" holes when I put on the Reese Titan. That went no problem. So I don't think I need to use any drill oil, right? These are smaller, 3/8" I think maybe smaller.
Second, I have to pull out the wheel well liners right? If yes do I need to buy anything to put them back in with, possible BOMBS?
Third, Removing the Overloads? Should I? Can I? I mean I have a good set of tools but that doesn't make me a mechanic, if you know what I mean...
Forth, Wondering how to jack up the truck and make sure at the recommended 10 PSI for empty running, that I have not modified, significantly the ride height.
I did a search and found other helpful suggestions on making sure the tubing is sealed and others. But any other advice would be appreciated.
---Doug
---Doug
