Intake system question
Save a little on your parts
Gear Vendors OD
Hello all, new to the site and I have a quick question. I was wondering what ya'll thought the best intake system would be for the truck in my signature? Thinkin about goin with an Amsoil 4510 filter with some aftermarket box like AFE, S&B or something like that. What do ya'll think?
I had modified my stock box with 2ea 2" dia holes cut in the front of it for ram air and a 5-ply AFE filter.
Ran this for approx 2000 miles, but replaced with it the AFE Stage 2Si (closed box) with the 7-ply filter for fear of rain getting into the previous setup.
I've ran the AFE 2Si for some time, its a good idea with some rough edges. (not thought out completely) ... To inspect or change the filter, I have to take the whole thing apart and the horn that attaches to the filter box doesn't line up very well, so its under some extreme tension. Plus, I have to disconnect the rad overflow hose to check the filter. The box doesn't fit up exactly with the foam seal on the fender. It has 4 clamps for the intake horn. If you are not extremely careful when you inspect or remove the filter, it can get damaged rubbing against the sharp edges of the box because the filter just barely fits in the box. Details, details...
Now, I have the PSM system with a cool hose from DPP with only two clamps. This retains the stock intake box for best fit and service. I'm running a Amsoil Eaa stock filter and have the stock AFE 7-ply to try later.
Go to Performance Systems Manufacturing, LLC and check out their new system for the pre-03 trucks and also check out their dyno and road test data.
You want to keep hot engine compartment air out of the intake system. Especially if you are towing.
Hope this helps,
Louis
I have a AFE Stage 2 system for my 98 and love it. I run the AFE Pro-Dry S when I drive it daily and use their Mega-Cannon filter when I go to dyno events. It has done all I wanted it to and provided me with very good service..... Andy
Thanks for the replies guys! Have you heard of anyone using the Icebox? I was checking that out too and was wondering if there were any comments (good or bad) about their box.
