Anybody who is thinking of lifting your truck, stay away from these tires. I've had three replaced under warranty in two years. The tread started seperating causing the tread lugs to seperate from the tire casing. This past Tuesday on my way home from work, I was cruising at 70 MPH on the lovely Long Island Expressway, when my whole truck started shaking violently. Many unpleasant thoughts were running through my head. I slowed down and pulled over. A fast look under and around the truck revealed nothing unusual. I then continued on my way at a slower speed, but the shaking got worse. Then it happened, the tire literally popped. I pulled over and could not believe what I was seeing. The steel belts in the tire broke blowing a huge hole right through the center of the tread. Fortunately my rim was undamaged. This makes it an even 4 crappy tires I've had. You will notice that Interco recently changed these size tires from 6 ply to 10 ply. Gee I wonder why? Buyer beware.
