Intercooler Fitting (Rubber Bootie)
bigger intercooler???
EGR front disc conversion
Looking for a rubber bootie (connecter) from the intercooler to the pipe that runs to the turbo on the right side for a 1993 w250. The Dodge part number is 52006930, Hose Charge Air Cooler Duct. My air conditionining hose has almost rubbed a hole in mine. The dealer does not carry this part anymore Discontinued part. Where can I get one like it?
Thanks
Dan
Do they HAVE to be the hump hoses? Or will regular silicone turbo/ intercooler boots work? The reason I ask is that I will have to extend the tube going from the intercooler to the intake when/ if I get intercooled :rolleyes:, and would rather run a little longer hose than have to weld on that thin stuff the tube is mads of.
Daniel
I have, and plan to keep on doing so. Cant help it; southern upbringing, then rodeoing. I have no chance. :D Make do with whatcha got.
Hey guys,
I just replaced all of the boots on my intake system with 2 1/2" high temp silicone hose, cost was less than $25 at my local hydraulic hose shop and it works great and looks good too! you will need 2- 5" long pieces and 2- 4" long pieces, though I wish I had gone 5 1/4" long instead of 5" they seem to be a hair shorter than I would have liked. good luck.
Proto
