Engine/Transmission (1998.5 - 2002) intermitent long crank
2nd Gen Non-Engine/Transmission rear brakes adjustment (drum)
2nd Gen Non-Engine/Transmission bent wheels - how much is too much?
99 long crank, tach works intermittently throws code p0336 cps signal cps is behind starter on these years also after awhile running tach starts to work and then stops then works then throws p0215 fuel injection pump control circuit, p1689 no communication at fip and also p1690 fip crank postion sensor the p0336 is the first code thrown when running and tach stops have seen a lot of injection pump problems with these codes before but cps code is confusing me. lift pump has plenty of flow and has oe IJP and 103,000 miles I believe the cps is failing but also think the injection pump is failing looking for some input from someone or is there something I am missing.
What i was trying to say without typing too much is your use of cps..............Replace your ckp sensor
p0215 possible causes
FUEL INJECTION PUMP RELAY GROUND CIRCUIT OPEN
ECM GROUND CIRCUIT(S) OPEN
FUEL INJECTION PUMP RELAY CONTROL CIRCUIT OPEN
FUEL INJECTION PUMP RELAY CONTROL CIRCUIT SHORTED TO GROUND
ECM
TEST
Thank you! I thought that but I like second opinions, I am going to replace the crank sensor first then see if any problems from there I think the codes are ghost due to the ckp.
