I have a problem. An under load intermittent no/low boost but with a P1693 DTC showing. No engine trouble light. No air leaks found. Runs good with good power. Removed Edge EZ, same problem running stock. Problem occurs under load, towing. Boost goes away, egts go up and remain for about ten miles on fairly level terrain. Had to drive 40 mph in 4th gear to keep egts down then suddenly boost returned. Your help is appreciated.
