Hey all,
I still have a slow fuel leak from the high pressure side of the IP. I tightened up all the injector lines to verify they were tight using a crow's foot. I think the center 12 mm nut may be what's leaking. Given the angles its hard to see for sure. Is there supposed to be a washer or something behind it? What is the torque spec?
I suspect this is leaking because this nut vibrated loose after I got the pump back from the diesel shop. I tightened it up with a 1/4" ratchet. Today used the same ratchet and got it to budge a little. I don't want to put too much force and break something.
Any ideas, espeically if there is a washer or torque spec?
Thanks,
Brian
Thanks,
Brian
