Is 3" exhaust enough?
clutchflite transmission
Bilstein Shock Information
What is the diameter of the stock exhaust on the 1995?
Mine needs replaced and I can get a complete 3" system, including muffler in 304 stainless steel for $325. Is 3" big enough? He can't go bigger.
Thanks,
Blake
Pennsylvania inspection
Another question in addition to what size original exhaust and whether 3" is big enough...
Do any of you guys in Pa know whether it is a requirement to have a muffler to pass inspection?
If so, I was thinking of having the guy put the new muffler in with flanges so it can easily be replaced with a straight piece of pipe.
Thanks,
Blake
Dang Ray! You da man!!! Most women can't take it that wide!:-laf
Stock exhaust is said to be good for up to 600 lb/ft of torque. Personally, I can't speak for performance as I'm running stock but of the systems I've heard, I like the sound of a 3" exhaust better than 4". A 4" system sounds deeper with less growl. A 3" system isn't as deep sounding but has a thick Harley like growl to it. I like 1 3/4" pipes as apposed to 2" pipes on a Harley for the same reason. But that's only my ever so humble opinion. :D
For that price I think I'd go for it if I needed an exhaust system.
Stock exhaust on a '95 is 3" turbo to cat, 4" cat to muffler, 3" muffler to 4" tip.
Blakers,
The rule of thumb I've heard is to use 4" if you are going over 350hp. Ties in with what Steve M said about torque.
The only question is: are you going to do any more bombing? If so, the 3" may not be big enough, otherwise it sounds good to me.
Gene
Thanks guys!
I wonder if the system posted is stainless or not. It doesn't say. Sure isn't a bad deal if it is.
Blake
Has anyone hooked an manometer up to the exhaust post-turbo to compare backpressure between 3" and 4" pipes?
Here's a thought. Go ahead with the 3" SS system. If (or when) you get to the point that more is needed find a 4" downpipe and then add another 3" system and run dual exhaust. Sounds as though you can get custom bending?
Rip's system is aluminized steel and he uses an Allied truck muffler. I just put the Allied muffler in my truck and it really sounds good. Much better than a straight pipe, IMHO.
BTW, I noticed my stock exhaust system is SS from the turbo to the muffler.
-John
That sounds like a good plan John. If sometime in the future I want to go to a 4", I can make it into a dual pipe system (mmm - stacks??;) ) or just take the whole 3" off and sell it to someone else. It should always be in good shape beings that it's 304 SS.
I'll go and check this guy's work out in the next couple weeks or so. If I like it, I'll give you guys the information so anyone else can go there too. He's located in Edinboro, Pa.
Blake
