In regard to oil, if you're using a good diesel engine oil, you don't need and should not use additives. It you introduce additives that are not compatible with existing ones, you can do more harm than good. Valvoline Premium Blue Classic 15/40 is a joint venture with Cummins for pre 6. 7L engines. I wouldn't mess with a proven, balanced formula. It has the best additives in existence.
Couldn't have said it any better.
If the Lucas snake oil is so great why don't oems require it? I know a lot of people run it but it I never will.
