Well the bug just bit me and after doing lots of search on the forums here I think
I have half a clue what I want and how to get there. But I know I am not the first and would like the benefit of others experience.
What I want is an increase in power without a major sacrifice in the economy (currently 17-20 mpg), nor do I want to smoke everyone out when I take off from a light. I believe my limiting factors from a durability stand point will be the clutch and the stock injectors. With my truck being a 97 with the 5sp I think I have the 215hp pump/injector combo? Currently the only mod is an aftermarket 4" stainless exhaust (no cat, not sure if it came with one?).
My driving style is average to slightly above average and I run empty 90% of the time, occasionally I pull a small landscape trailer and eventually I'll be towing my car to the track (open trailer) so I don't have any real towing restrictions to speak of. I live in central Jersey so altitude is not an issue.
With that being said I am thinking along these lines, tell me what you think
Gauges are here and just need to be installed. (Autometer EGT and Boost 60lb)
KDP kit is order and on its way
3k Governor Spring Kit
TST #10 plate (or #11???)
Air filter/box/snorkel, but which one and which stage??
Timing??
At that point I think I'm at the limits of the clutch and probably the stock injectors? So I think that's as far I am willing to go at this point.
Is this reasonable? and is the order correct. Ideally I would do all of this at once so the order is less important than the component selection. I will end up doing this work myself to save some cash, and also to be come familiar with this beast.
The truck has 3. 54 gears and I run 265/70-16E tires if that helps
Thanks for any and all input
Timing??
