ISBe Marine High Flow Head
HELP! Trucks on the side of the road
Any mix syn & Dino?
I noticed on the Cummins website that the 380 hp ISBe marine engine is available. The literature states it is the same base engine that is in the Dodge Ram, but has a higher flow head on it. Anyone consider trying the new head? I wonder how much it is or if it would even mate up to the Dodge intake/exhaust correctly.
I looked it up and its interesting... It would be cool to throw the head and turbo on it :)... wonder if its possible... The dimensions are the same as our engine
question is how much $$$$$$$$$$$$$ would it cost to do?
http://www.cmdmarine.com/pdfs/4081898_0903.pdf
Quoting the text from the above link:
"With its roots going back to the proven 6BTA5. 9, the
QSB5. 9 is providing a Quantum Leap in the marine
industry by incorporating the latest diesel engine
technology. A high pressure common rail fuel system
virtually eliminates start up white smoke and black
smoke, improves fuel economy and significantly reduces
noise. The base engine uses the same components as
found in the 2004 Dodge Ram Pick-up Truck powered by
the Cummins Turbo Diesel. The engine includes a new
cylinder head with four valves per cylinder, which allows
the engine to breathe easier for increased acceleration
and torque. "
I don't think they are saying that the marine engine has a higher flowing head then our trucks. Instead they are saying the head flows better than the 12 valve 6BTA5. 9.
Carl
Carl,
You beat me too it...
If I remember correctly the "Cannon Ball" truck had about the same HP upgrade with just a Cummins ECM program.
-Richard
I would imagine that with the correct factory timing and fuel map they had it under control. I sure wish they would offer a HP upgrade thru Cummins via a flash. I don't care about warrenty as I am my own warrenty station already...
-Richard
Originally posted by mattymac
I wonder what they are doing for the EGT issue for the higher HP?
On a marine engine of any kind. The engine's coolant (jacket or raw water) flow through water jackets in the exhaust manifold to keep it cool.
