When I troubleshoot difficult problems, I like to remove all of the variables that may interfere with troubleshooting. That is why I would disconnect the grid heaters until this problem is resolved.
With the grid heaters disconnected, you will be absolutely sure that they will not be affecting the voltage readings at the battery before and after the truck is running. After starting the engine, voltage at the battery should approach 14 volts fairly quickly, unless the battery is deeply discharged.
Can you perform the above test?
Leave the grid heaters disconnected! Turn on the headlights and set the blower fan on high. Does battery voltage still remain around 14 volts? Take the truck for a drive long enough to reach engine operating operating temperature. Does the battery voltage still remain around 14 volts?
After your test drive, reconnect the grid heaters. Restart the engine - the grid heaters should not activate. Is battery voltage still around 14 volts?
I would disconnect the grid heaters and measure voltage at each battery with headlights on and heater fan on high while the engine is running. Battery voltage should remain near 14 volts. Drive the truck. Again, battery voltage should remain near 14 volts.
I will make one last attempt. Disconnect the grid heaters and leave them disconnected! From what I have read so far, you have not disconnected the grid heaters and driven the truck. That is what I want you to do. My guess is that the charging system will function normally without the grid heaters connected. If it does not, then you will know that you have a problem with the charging system.
I am not saying that the grid heaters are the problem, but if you don't disconnect them and leave them disconnected, you are going to find it very difficult to diagnose whatever problem you have, especially if it turns out the grid heater operation is the problem.
The grid heater control circuitry could be telling the grid heaters to post cycle for too long, or could be telling them to post cycle together instead of alternately, or you could have a battery in such poor condition that there is no reserve capacity while the grid heaters are post cycling. Remember, a perfectly operating charging system cannot produce the current flow that grid heaters draw while they are activated.
I was going down the road after dark and the headlights kept getting dimmer until it warmed up and thd alternator kicked in.
The alternator does not "kick in". It begins charging immediately when the engine is running. This sounds more likely that a heavy electrical load (possibly the grid heater operation) has just been removed, which now would allow for the alternator to direct its output to the lighter electrical load and to recharge the battery, consequently battery voltage would rise to the 14 volt level.
I disconnected the relays and started the truck. I was grumpy but started and the inside volt meter read around 14 and the battery was 14.3.
This information indicates that the charging system is functioning properly. The alternator quickly brought up the battery voltage immediately after starter motor operation (a heavy current draw).
So, please disconnect the grid heaters and leave them disconnected. Drive the truck and report back.
- John
