Just installed my EZ Box. This thing is appropriately named. What wasn't easy was getting both arms into that tight space to plug the wires in. Took it out for a test spin and have to say that I am very happy with the initial results. The turbo spool up is much more pronounced. Max boost was 26 where before I saw a spike of 20 once, but normally 18-19 was the highest. No smoke that I could see and EGT's seemed about the same. I'm going to do some 40-60 times here in just a few minutes
. I'll post results later. Can't wait to tow and see if/what the mileage improvements are.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
