JD RX75 ride on mower problem
Holy diamond plate Batman!
DTT need help in Memphis
My mower has a 9hp Kawasaki motor with electronic ignition. Having problems with it losing its ignition spark after it runs for a while. It will stop without any warning. let it sit for 15 to 20 minutes and it will go again. When I check the spark at the plug after it had died the spark is very weak, almost none existent. When it is running it runs fine with a strong spark. I thought that it was the coil so replaced it with a new one and still have the problem. What else in the ignition system can be causing it to shut down??? I did post on the YT tractor forum however have not come up with anything other than the coil pack.
Is there rust on the magnet used with the coil on the flywheel? Have seen that be a problem before. Just used emeory cloth to remove it.
Rectifier or voltage regulator problem (don't know serial $)?
  • KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
    15A PT11191 RECTIFIER 1 - 595000 (RX75,SX75)
    15B M76939 VOLTAGE REGULATOR 1 595001 - (RX75,SX75)
List didn't come out quite like I wanted it, hope you can follow it. This what I cut and pasted from Deeres website. Hope to save you some time looking it up.
The key #'s are for their on screen location on that page in the "book" if you didn't already know.
