Jordan Brake Display Location
Any one know anything about horse trailers???
o6 and exhaust brake.....one more time
Okay in the midst of installation of the Jordan Brake Controller. Anyone found the perfect mounting loction of the display module? Oo. :D
No war just wondering? :confused:
I put mine below the ashtray directly under the ashtray. The top front edge of the Jordan lines up with the lower seam opening of the ashtray. Works very well there for me ;)
Mundgyver/Nate - Okay will see how both locations look. Mundgyver - Only problem I may have to below the ash tray is I put the inverter/converter in the ash try to plug in my computer when running my DeLorme software and GPS. Ash try may be in the way will see to easily see the front panel of the display.
Thanks gentleman.
I have mine just to the right of the pedal adjust switch, you can see it while driving through one of the holes in the steering wheel.
Yep that is a good location. That is where my Smart Tire system is. My Jordan is on the other side. It is all a matter of comfort level and what works best for the driver. ;) :D
Okay finished install and mounted the display to the right of the hood release and in line with the brake pedal thus no S turns on the cable a straight shoot. Thanks for the help.
