Running pressures that high will damage the VP44 also.
I hope not, cause I haave been ruuning mine at 45 psi at idle, 37psi WOT for over 50K. Doesn't seem to have hurt anything.
Dave
Only problem you have with a FASS or something is that you need to hit up summit racing for a line splice so that you can put the fuel pressure sensor in the fuel line. If you have a stock lift pump (even on the frame rail) you can just use the supplied fitting to install it.what are you using for a lift pump? anyone know if the juice will work with it ok?
