Just got my Juice/attitude installed
AFE Pre-Filter
Check out my HP addition...
BOY what a differance, everyting else in the truck is stock so i wont run above 3-5. My egt's run between 500-900 most of the time go up fast but come down just as fast.
Also monitor Boost, and slip, and backdown. So far no slip's
its awesome :--)
Did you play with the the low boost fueling funciton? Is there a noticible diff in smoke and/or low end response when you change the level? How's the power in level 3? Better bottom, mild, top?
I did set the LBF to 5 no smoke though. Responsiveness at 3-5 is very nice. Power is better off standing start and when in 4th also noticeably quieter when crusing along, didnt expect that
Gaskicker said:
I've done some 1/4 mile runs in 5x5 and only seen slippage of 5% - not bad considering bone stock trans.
I have not seen any reduction in ets with box above level 3 with stock autos. With a good trans Oo.
Bob
I dropped 2 seconds off the 1/4 mile from stock as well as 2 seconds off of 0-60 time.
1/4 mile times
Stock - 17. 5
5x5 - 15. 4
0-60 times
Stock - 8. 9
5x5 - 7 flat
These are prior to having the HOT Juice loaded. Edge tells me that the HOT Juice will tear apart a stock trans in a week of hard driving, so I will wait.
