So got the new mag last night and was reading over the oil cooler failure article right in the beginning. How many of you guys have had your oil cooler fail and cause the coolant oil mixing issue? This was the first I had heard of this failure and from what I took out of the article it seemed to be more of a common failure than a blown head gasket causing the oil/coolant mixing. I change my coolant just about every other year or so, but is this something I should be concerned about failing? Just curious as to what you guys have experienced.
Thanks, Joe
Thanks, Joe
