Comp box mystryes!
All,
In my search for what might be wrong with my newly installed comp box, I stumble on this post. I just wanted to let you know I had just pierced my pump wire on Saturday and was enjoying the full power of the COMP VS the EZ mode. So I was playing around with the smoke settings, you know, the second set of adjustments. Anyway I had tried changing them to different levels like, 3X3, and 4X3 etc. I thought that that if I left the 5X5 alone I could always put it there when I needed it, and I would have 5X5. Well that was not the case. When I went to 5X5 mode the first time before I messed with the boost settings I would get a nice black cloud of smoke at WOT. After messing around with the setting on Sunday, I started to notice that when on 5X5 mode my magic smoke was not there??? Yet when the boost came up, the truck ran strong! Yet I was still mystified to what was going on. So to the TDR I came for answers. I found lots of stuff to check, but none of them fixed my problem. Then it dawned on me that I had changed the setting on some of the lower levels like 4X3. But I thought that it should not make a difference when in 5X5 mode. But I figured I would change all level’s to sub level 5 and see what happens. It turned out the only one I had left changed was 4X3. So I took it to 4X5 then bumped it up to 5X5 and now 5X5 is working again, and the magic smoke is coming out the back, and the transmission is slipping like mad( that is getting fixed on the 18th)! I looked at the instructions again and it says each level is programmable for it sub level. It does mention something about using the right arrow to get the lights to all show. When ever I go to the sub level menu they all show and flash on and off. What I did was adjust the sub and then try it. I am wondering if all the lights need to not be flashing to set it??? I will try it tomorrow and see if hitting the right button a few times clears up the flashing and then reset the level’s and the sub level’s and see if 5X5 still works after that. Some of you may have known this, but I did not see anyone post about this. So I thought I would share what I found out after reading this post!
Chris Brandt
Anchorage, AK
