Hey all, stranded here in Illinois. Just wanted someone to tell me if this sounds like a wheel bearing:
I was driving down the freeway at about 70 mph and the truck started jerking and pulling to the left. At first I thought it was wind pushing the truck until it started vibrating, enough to make me think I had a flat tire. When I stopped and looked I didn't see anything, just some smoke coming off the left front wheel. When I crawled under the truck I didn't see any obvious damage, just a small amount of dark material in the bottom of the wheel. Tried driving slow on the shoulder just to see what it would do, and it would struggle a little, like I was trying to start with the brake on, although sometimes it would come out of that and roll forward just fine. Called AAA and had the truck towed to the nearest garage, but it got there after they closed so I won't know until tomorrow whats wrong. Does this sound like a wheel bearing? If not what else could it be?
Assuming it is, I'm concerned that since it was a catastrophic failure there could be some damage to the spindle. I'm not really familiar with how this unitized assembly works though, it is possible the whole spindle will need to be replaced if this is in fact a bearing failure? Or could I be so lucky that this could be fixed just by replacing the hub assembly? Thanks
