K&N in stock air-box
Is there a trick to pre-turbo EGT probe?
Would've Killed Myself Today...
I am looking for an answer regarding the K&N,
can one be used in the stock air box or is this not a good idea? I am sure this topic has been covered but I have not been able to locate it, thanks DOC NIELSEN
You can use a K&N in a stock airbox, just use the air filter sealing grease. If you go off road alot, you may want to consider the Amsoil only because it has foam which acts as a prefilter. The preffered method is get rid of the airbox alltogether, get a K&N RE-0880 and a 25-0880 prefilter and attactch it directly to your stock air hose. Lots or power, lots of noise, works great.
Yes there is, it's what I use. If you live in a dusty area I would not recommend it. Some go with the round style and remove the stock air box, and for more filtration they add a foam piece over that. For me the stock box+K&N work great. I'll try and find the P/N for you.
Edit: K&N part # 33-2056
98. 5 3500 SLT Quad 6X6 * 3:54 Auto * Waterfall black/red * Custom dually flaps * Rhino lining * All acc's w/leather * Muth signal mirrors * K&N * Catz MSC's * 55watt back up lights * Optima Red Tops * 80/100 Head Lights * Silencer ring "AWOL * BD exhaust brake * Banks EGT/Boost/Temp gauges * Mag-Hytec DC&TP * SS bug screen and fender trim * SS Stull diamond line running boards * SS 4" turn down * grill inserts
My Dually
[This message has been edited by Justbeamn (edited 05-09-2001). ]
I installed a K&N in the stock airbox. I noticed an improvement in the turbo spooling up. Next I removed the stock airbox and replaced it with a K&N RE-0880 with a red
25-0880 prefilter cover. I noticed the turbo spooled up faster sop.
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with Goodyear MT/R 315/75R16, Smittybuilt stainless nurf bars, ExTang BlackMax tonno, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!! "I AM GLAD I DID NOT BUY AN AUTOMATIC, JMO"
I have the K&N stock-box filter, and I am in home construction. This winter, I just used the K&N as it came from factory. However, for our dusty summers, I'm going to remove the foam pre-filter that came with my stock D/C filter and glue it to the bottom of my K&N. I think that will help a lot.
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
