I have the front off my engine to fix some small oil leaks, incl. the side cover gasket. I ordered the KDP kit from Genos. To be blunt, it doesnt fit! The kit has the angled tab, which should be right for this engine. The engine has about a 1/4" raise where the pin sits (the bolt for the tab is 1/4 lower then the dowel pin hole). The only way I can get the tab kit to fit anywhere near right is to add 2 small washers on the bolt between the tab and the gearcase. I dont like this! Even with the locktite, I could see that moving or backing out.
I dont know how to tell of this has the "fixed" housing or not. The pin was below the surface by at least 3/16", when I hit it with a punch, it felt tight. It looks like it has a ream (small ridge) or something on top of the hole, yet I cant really catch a small screwdriver on it.
I called Geno's to question this, they said to put a washer under the tab and they hadnt heard of this before. I did as they instructed, but feel uncomfortable with this. If it fails, there goes my engine. I dont want to cause a problem by trying to prevent one. Anyone else dealt with this?
