KN-RE0880 prefilters?
Best e-Brake for 12 vavle automatic transmission?
Clutch Question
I have decided to go for a KN-RE0880 and need to find out about the prefilters. I know there is a foam one and I have the part # for it, but I know I read a post the other day about a silk cover for the 0880 that was used to keep water out of the filter. Does anyone else remember seeing that post or have the part # for it?
John D. Rathert Jr.
01 2500 SLT+ QC LWB 4x4 Auto 3. 54 rear end, Forrest Green Sport with all options avail. DC Nerf Bars, DC Grill Gard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DDT's torque converter - valve body combo, 275 RV injectors and Diesel Dynamics 4" Exhaust.
Airbox Mods, new turbo and SS fuel lines in planning stages... .
See My Truck
Dads truck: 98. 5 3500 SLT QC LWB 4x4
Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck)
See 5 Diesels and a Gasser
Winter fun: 2000 Skidoo Summit 700
FREE HVAC!!
Check with a marina if you can. I bet they would know where/how to get one.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
JR2 there are two types of pre filters you can use with the RE-0880, one is a foam type part #25-0880 and the other is a polyester material #22-8035pk. I am going to try to locate the 22-8035pk tomorrow.
1996 4x4 3500 4. 10 5spd, Diesel Dynamics stage 2 injectors, #5 TST plate, Govoner spring kit, 16cm2 housing with 4" exhaust, Cummins exhaust brake, US Gear overdrive, Grover air horns, Mag-Hytec cover, and more.
BPINE and JR2, the suffix to the part number denotes color. there are at least four different colors available. One thing to consider though, this particular prefilter is stated in the K&N catalog to reduce flow by no more than 10% whereas, the RE-0880 foam prefilter has a 2% restriction... something to consider.
On the flip side, the owner of the local 4WD shop (also owner of the *****in bright yellow jeep in last years Four Wheeler Top Truck Challenge... one of the top ten) told me the silk type prefilter is the hot tip for elimination of the most minute particles. I was told these are especially popular with guys who like to play in the sand.
Hey BPINE, Bill (Kondolay) said I should ask you what the real story behind the school bus incident was. LOL #ad
[This message has been edited by John (edited 01-24-2001). ]
Guys, thanks for your help, I got the same part # (#22-8035pk) for the silk/polyester prefilter from a non-tdr memeber who emailed me. If the prfix of the part # is for color, what is the part # for a black cover? That is the color I really want.
As for loosing 10% of your flow through the filter, who cares it still flows way more than the stock filter ever did.
I only plan on running it when it is real dusty (spring in Anchorage is dusty) and then go to the regular prefilter. If anyone has the time, maybe list all the different colors this thing comes in.
John D. Rathert Jr.
See My Truck
FREE HVAC!!
Well I ordered that RE-0880 and the regular prefilter from summitt today, they did not have the polyester/silk prefilter. Carparts.com had the part #, but it was listed as a filtercharger and was just over $50. I was not sure it was the correct item so I did not order it. Any one actually laid hands on one of these yet?
