Ok so ive got my stabalizer installed and its now got a steady pull to the left... . Overcharged?
Can you adjust pressure with a simple tire pressure guage. I know to add PSi you would need nitro... . I think i need to go down a little.
They come with75PSI? Can i check mine with tire guage without loosing too much?
Don could you move the mounting point of the plate down with some spacers? Is the pan rounded where it attaches with the u-bolts or could you just put some kind of block in there?
Don,
Thanks for the heads up! I have a Power Wagon steering damper skid plate on the way and already have a streeing brace installed. I agree with you, I want significent clearence between the extended steering shaft and the skid plate... . may look at doing a little trimming or adding a hole in the skid plate to insure clearance.
Thank you!
