I have a KSB1B and I have to be at reasonably high rpm's (1800 +) before significant boost (10 psi +) starts to come in. I get the impression that I do not have enough exhaust drive pressure until I get to the higher rpm's to get the turbine fully spooled up.
I get the impression that I can change the size of the exhaust section to a smaller cm**2 and get faster spool up. The EGT temperatures would go up since it would have a smaller turbine cross section.
When I am at full throttle towing (13k) at the lower RPM's (less than 2000) I have PLEANTY of black smoke which leads me to think I have enough fuel, just not enough air.
What EXACTELY do I measure and WHERE to determine what my exhaust section cross section is? so I know where I am right now.
It is NOT wastegated. The maximum boost it will generate is about 20 psi and that is up around 2000 - 2400 rpm. It cruises towing (O/D out, 13k 5er) 62mph @ 2400 rpm at about 10 psi.
Ideas?, thanks in advance.
Bob Weis
Bob Weis
