%$##@(* Lance cabover strut mounts!!!
Michelin XPS vs. Goodyear Wrangler s
New 03 towing break in
Or perhaps the real blame lies with Dodge?
I attempted to install a set of Lance cabover strut mounts tonight on the truck. After drilling and tapping the holes, I naturally went to mount the brackets.
Wasn't I surprised after just getting the 5/16" mounting bolts snug THEY STRIPPED OUT!!!! I couldn't believe it. It wasn't like I was using a great big honking 1/2" breaker bar to tighten them. Just a little 3/8" ratchet.
Am I ever ******. 4 now useless holes in the truck. Actually only two are stripped out. One on each side. I don't think I want to run 'em with only one bolt anyways. I'd probably strip them out too when I got them tightened to a massive 20 ft lbs or whatever I got the others to.
Maybe I can salvage it with some helicoil but there ain't much to get ahold of on that thin sheet metal I guess. :mad: :mad:
Maybe I should drill the holes a tad larger and tap for a 3/8" bolt then tighten the bolts with a wet noodle.
I wondering even if I do mount the brackets how long they'll hold up given the "strength" of the metal they're bolted to. Jeez!
Dang it anyway!
Tim
If you need to why not just put 'rim nuts' in to set the bolts. The gas struts operate under compression anyway and don't need a lot of torque to secure them.
Ok, I'm confused. Where did you find enough thickness to tap. I am under the impression those things mount to the sheet metal of the fenders. If you found enough meat to tap you should be able to get a heli-coil to work.
Well, according to the official Lance instruction set, the metal where the bolts attach is "thick. " (Their words, not mine. :)) They also state that because the metal is "thick" that it is recommended that the holes be tapped after drilling.
The metal where I drilled the holes appears to be approx. 1/8" thick. Maybe a tad more.
They include 5/16" self tapping bolts with the kit.
I obviously took their advice and tapped the holes.
I think I'll re-tap the stripped out holes to 3/8" and gingerly torque in 3/8" bolts.
I guess the body sheet metal is pretty soft. :(
Tim
There are these rivets with threads you can put in the hole.
Here is one type . I see there not listing 5/16 but I know they make them, just not sure where to get them. The larger then 1/4 is to big for the hand tool, they have a threaded tool for installing them.
I use them for mounting things on my Compound Bow. I bet it might actualy hold better then just threads in the metal because there "crimped" into the hole, and leave you with about 1/4" of thread.
DOH!
The answer is 5/16" sheet metal screws. The screws supplied by Lance are standard shallow thread machine screws which can't grab like the big threads on a sheet metal screw.
I haven't tightened the sheet metal screws beyond what I can manage with a screwdriver, but at least they tighten up.
Tim
I also stripped one bolt on each side not soon later after highway bumps other bolts were also stripped . what i did is remove eveything and put a 3/8 inch thick plate already taped to 5/16 under the cowl and held in place with sicon when dryed i reinstalled wipers and plastic and reinstalled brks and bolts . 12,000 miles and so far good
sicon or silicon?
Watt,
Thanks for the feedback. I was wondering if a guy could epoxy a piece of bar stock on top of the sheet metal to give the brackets something to bolt to.
I am hoping that the 5/16th sheet metal screws I used will hold. Only time will tell.
My question to you is, is "sicon" a brand or type of adhesive or is it a typo for "silicone?"
Thanks,
Tim
The only solution is to use blind nuts or rivet nuts. The sheet metal is to thin to hold a self-tapping screw or to tap. I learned this in the middle of Wyoming when one of the brackets (installed by Lance dealer) pulled out.
You can get them at McMaster-Carr. Make sure you watch your "grip range" . On my truck, one of the holes goes through three layers of sheet metal, the others go through two layers.
I also trimmed back the plastic molding so that the brackets would be "metal to metal". You don't need a special tool to set them, you can use a bolt and nut to do it.
My advice is to fix them now, don't wait until your in the middle of no where and have to take your struts off.
rivet nuts
MGordon,
Yeah, that sounds like good advice. The sheet metal is very soft so I really don't have much confidence in the sheet metal screw fix.
It appears to me anyway, that the front holes go through 3 layers and the rear holes go through 2 layers on my truck. Not much there at all even though Lance warns the installer that the metal is "thick. " I guess maybe it's thick in the RV biz. :)
Thanks again,
Tim
Tow Pro has the answer, nut sert is what I've always called them. Anytime you need threads in sheetmetal, that's the way to go.
