I hope the moderator will leave this here as more guys will see it and maybe get me a good answer.
My '07, 5.9 has a PRXB Pacbrake mounted on it and it has worked flawlessly for 5 years. I used the supplied small Viair compressor that mounted at the front of the engine above the intake manifold and the .5 gallon tank.
This last trip I took, I needed air supply to fill a low leaking tire out in the "Boonies". It did a very poor job trying to inflate a 285-75-17 tire. I could get it only to about 50psi and it took a "Month of Sundays" to fill.
SO........ I ordered the LARGE Viair 480c, 100% duty cycle, 200psi capable compressor, a Viair compressor mounting bracket and a Viair 2.5 gallon, 200psi tank.
I mounted the compressor bracket on the FRONT PASSENGER, inside rocker panel and the tank just behind it under the right rear seat floor.
I rubber mounted the bracket with grommets to the rocker panel and the compressor is also rubber mounted with the supplied grommet feet.
When the compressor cycles on, it is noisy and transmits into the cab. Atleast NOW, I have 145psi air, a good volume tank and a fast recovery compressor.
The ISSUE is the NOISE! Anyone got a good suggestion on quieting things down? I want to keep the compressor located where it is or in a well protected place. Any of you guys mounted a compressor on your trucks and had a good success with them being quiet? I'll try to take some pics and post them.
