Trucks getting closer to running everyday,, I had only a block w/pistons earlier today, now I have the motor about ready to drop in tomorow, so it might be as early as Tuesday when I let yall have a impression of how my '55 goes.
Right now, I need to order a transmission yoke, a Water pump seal, and I'm waiting for my injectors.
Here's what my truck will have,,,
PDR Stage 1 ported and O-ringed head
PDR Cam
Head Studs
Mach 4. 8 injectors
Normal COMP
J. R's experimental '55
FASS w/-10 Line and -6 return line to the back of the block.
Probably won't have a fan, I'll be using electric fans
SBC FE
And probably too much Walmart hotrod paint.
The only thing I'm really waiting for is a MAD ECM, and a COMP from Maddog to make my truck "finished". Then I'll need to do alot of other little things since the truck has pretty much been sitting since Thunder in Muncie '03.
Merrick
PDR Cam
Head Studs
Mach 4. 8 injectors
Normal COMP
SBC FE
Merrick
