Engine/Transmission (1994 - 1998) Leaking Injectors
2nd Gen Non-Engine/Transmission 1995 recalls
My injectors on my '95 cummins are leaking. What should i do to correct this problem? should I replace the injectors all together or is there something else i could do to fix it?
Where are they leaking at? If it is the small return line that runs to all of the injectors it could be as simple as new copper washers.
I don't know if the leak is internal or external, I took the truck in to a aamco to get my transmission checked on because i just had it rebuilt. and their mech looked over my engine as well and just said my injectors were leaking.
:-laf First advice... ... ... ... avoid aamco,next pop your hood to see if there really is a leak.
