Hello all.
Just got through changing all my valve cover gaskets and now and see I have the #3 injector has a 'slight' leak - more of a seaping.
Amazing how getting all that leaking oil out of the way can help.
I would imagine the first step would be to see if it can be tightened a bit.
How best to do this - still learning.
I see there is a hard line that is attached to all 6 injectors along the side, looks like it is designed to equalize pressure - yes/no?
Do I remove this line and then the injector line in order to access the injector to tighten it down?
Are crush washers involved between the injector and block?
It's not bad at all, just want to see if I can keep things clean and problem free.
