LED light reccomendations
New Road Armor front bumper install and impressions
Sanden Direct AC compressors for 1996-2005
AH64ID
I’m looking for recommendations for a couple different sets of LED lights.
I’m installing a front receiver between my tow hooks and wanting to put a LED light bar on either side of the receiver. Hoping I can find a quality one that’s approx 1.5”x8” in a flood pattern.
Then for the rear I’m looking for flush mount 2”x2” square LED lights, also in a flood pattern.
Any recommendations?
I have four 4" Rigid lights in my Buckstop bumper. Two spot on the inner pair and two flood on the outer pair hooked up to the existing flood harness. Lights up the night! I have two of the 2"x2" flush mount Rigid flood lights on the back of my flat bed which really helps when backing up or loading. My brother uses Rigid on his race truck so that is why I went that direction. I have no experience with the other lights mentioned.
If you don't mind buying Chinese, I've found some great deals on ebay. The ones I found are good quality. I installed docking lights on my 5500, great when backing in campgrounds during darkness.
Going to add two more closer to the front.
Cheers Ron
I frenched a pair of 2"x2" Rigids into each bumper.
The only reason I went with amber up front is that during blizzards/heavy sleet, I turn the headlamps off & just use running lamps + the ambers - makes it far easier to see where the black ice on the road ends & the ditch begins.
The rears are wired into my cargo lamp dash switch.
