I seen this advertised in Geno's catalog an wonder if anyone has purchased an tried it out. It says this option does not require the installation of X-Monitor. Is this just basically a set up of fuel pressure gauge without the gauge an a warning light in it's place. Is there a certain psi you can set for light to come on or is it when it reaches 0 psi. What are it's benefits over a fuel pressure gauge if there are any.
Reading about VP44 failures in 2nd generation trucks showing lift pump failures being the culprit causing the failure to injection pump looks like there could be some sort of warning indicator that the lift pump is failing. A lot of people did'nt realize there lift pump had even stopped working.
I would like to have some sort of fuel pressure monitoring system for my 3G, but really do not want any sort of fuel entering the cab area in case of a failure to the gauge. Really don't know what I want at this time. :-laf
Thanks for any Replys
Tony
Tony
