Fellas!!! Praise the Lord its DONE!!!!!!!! i got 3 relays on the head lights and 1 on the tail. as youll see in the pictures i put the tail light relay directly above the harness that plugs into the dimmer. and the 3 for the headlights i spliced into the wires that run down from the steering column.
- RED wire with PINK stripe is the highbeam lead
- PURPLE wire with WHITE stripe is the lowbeam lead.
so seeing as how i wanted to get the lowbeams to stay on when the highs where activated, i pigtailed two wires off the highbeam lead coming from the switch, and then pigtailed two wires from the lowbeam lead coming from the lights. that way the highbeams also activate the low beams.
- the taillight wire was BLACK with a YELLOW stripe.
Everything works fabulously! the lights are brighter due to the full 12. 5v theyre getting. and i have high and lowbeams at the same time. when i hit the highbeam lever on the column you can hear the 3 relays "CLICK!!!" if you hold them you can feel it, those suckers realy "CLICK!" :-laf
a SPECIAL THANKS to MATT & PETE who helped all this make sense to me. i couldnt have done it with out yall. really. thanks a bunch, guys.
(for the record, there where plent of headaches with this little job! i bout lost it when trying to re-install the dimmer switch, its so closterfobic under that dang dash ESPECIALLY when you have 3 gauges and cablight wireing all over underthere! man a live i aint gettin underthere anytime soon.
:-laf)
close up of the splice
the wires
only lacking the positive and ground wires
relays for the headlights, below the column
relay for the taillight, directly above the dimmerswitch
