For anyone else that has had the rubber sockets and housings melt due to very hot factory bulbs I found a solution. I went to LEDLight.com LED Lights, LED Lamps, LED Bulbs and found a replacement for the hot little bulbs. Of course this was after I replaced the little lenses due to the factory ones being totally useless. You need the T10 wedge 3 LED light, although not as bright as the regular ones but they are ALOT cooler and should stop the melting. There are total of 3 T10 lights 2 of them offered are brighter just which ever you want to use.
